HELP! My water softener is leaking.
Old 07-20-19, 02:06 PM
Where the water is leaking out:
[img]https://*******/4JSjvJb
Where the water is accumulated:[img]https://*******/KXXtBLM[img]https://*******/tsrK63r
Seems to be the water is leaking from here;
[img]https://*******/s1cCtQh
And then it accumulated in the blue pan, and flow out of the back hole.
This website wonít let me upload picture from Imgbb
But itís such a small leak, hard to believe itís the reason to cause a pond of water on my floor. Seems like an easy fix but I have no experience of any of this.
Old 07-21-19, 10:41 AM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
There are No photos or a way of getting there.
But with the from behind leads me to think that it is all in one unit, like sears , GE or the like and the salt water is over flowing?
Putting the system in bypass will stop the water from over flowing or leaking out the back once the pressure is down to 0 in the tank.
More information on type of system would help if photos can not be posted.
Old 07-24-19, 12:22 PM
I just changed the oring and it still leaking
Itís the GE gxsf30h01
Old 07-24-19, 04:21 PM
Akpsdvan's Avatar
What o ring did you change?
Is the bypass lined up with the valve body? is it straight in?
I am in the dark as to why your system is leaking, need more information on Where it is Leaking FROM...
