Water softener motor on
Old 07-23-19, 02:07 PM
A
Hey guys. Iím new here I think Iíve run into a problem with my water softener. The motor sounds like itís continuously running, thereís water in the salt tank and thereís no drainage from the hose. Not sure what to take apart here. I shifted around the salt to make sure thereís n bridges. I hear the motor even in bypass mode. Itís an older rainsoft model. Pls help
Old 07-23-19, 04:07 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
Depending on the unit the timer motor may make some noise as it ages.
Putting the system in bypass will not Change How the Motor runs , un plugging it will stop the motor.
Is there water to drain with the system not in bypass?
Is it Digital display?
