Culligan Brine tank water or no water..
Old 09-04-19, 09:08 AM
D
I just bought a house with a Culligan Medalist Series 8.
Should the brine tank have water at the bottom. Mine is probably got about 6-8 inches with salt.
I've been watching the salt level and it doesn't look like it has depleted much.
I checked the time and that its set to regenerate daily.
I've kicked it off a couple times manually.
Old 09-04-19, 05:41 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
Culligan is one that fills at the end of its cycle , so there should be water in the salt tank or brine tank.
If the salt is not going down , then the unit is neither pulling out the brine or putting water back in.
Is the system in service? or is the bypass handle in bypass?
If you start a cycle does water go to drain?
