Centaur carbon
Old 09-04-19, 06:37 PM
Centaur carbon
Possible to renew gac by back washing with strong peroxide injection? We have about 12ppm hydrogen sulfide and every year or two it starts getting smelly even with my normal peroxide injection... I usually do a few backwash with stronger mix when this happens, and smell goes away. Just wondering if gac eventual goes bad etc? I put current centaur carbon in about 3 years ago...
Old 09-04-19, 11:13 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
Might look at increasing the peroxide injection. Either increasing the mix or increase the injection amount, or increase the amount of peroxide in the storage tank.
At some point the carbon does go bad, nothing lasts forever.
Old 09-05-19, 09:58 AM
Yes, going to look at getting a more adjustable stenner pump so I can use straight peroxide, not worry about mixing it and becoming dilute etc...
Any idea how long centaur carbon will last on average? Is there a way to prolong its life?
Thanks,
Old 09-05-19, 05:44 PM
Akpsdvan's Avatar
What grade of peroxide?
7% is already some thing that one has to be careful with.
It all depends on what is in the water the amount of peroxide and the amount of water usage each day.
Also the ratio of peroxide to water. And then there is the amount of carbon in the tank, ie cubic feet?
Are you going through the carbon to fast? 1 cubic feet but your trying for 10gpm?
Old 09-09-19, 11:49 AM
I use 35% peroxide to make about 7% solution in a reservoir tank, and run that through a stenner pump... I'm thinking of just using a new adjustable stenner pump with straight 35%...
My current carbon is about 3 years old... not sure if I can let it go bit longer... I did a few backwashes with stronger solution and hydrogen sulfide smell has went away, so not sure if carbon is ok again.
Old 09-09-19, 05:23 PM
Akpsdvan's Avatar
What is the pump settings?
How long is a stroke and how often is it going?
Is it controlled by the well pump or a meter?
Old 09-18-19, 08:52 AM
Using stenner pump, not sure of pump stroke etc. I just set it to inject a solution that ends up hardly showing up on a ppm test strip... stenner pump is wired to the well pump and injects when pump comes on...
Old 09-18-19, 09:13 AM
Marq1's Avatar
Received 309 Votes on 289 Posts
Carbon is excellent at removing chlorine, but the higher the level of chlorine exposure the shorter the life span.
I also have a chlorine injection system for low level iron removal and my carbon filter is going on 10 years.
I have never heard of a system that backwashes the carbon filter using chlorine but assume your getting high levels of bacterial accumulating in the filter which is causing the odor.
Use caution with high concentrations of any chlorine, my Stener pump is by far the weak link with my low chlorine concentration, I go through tubes a couple time per year which may or not be directly related to the chlorine.
Old 09-19-19, 06:27 AM
Yeah, aware of the harshness of using chlorine, thats why we are using hydrogen peroxide... bit more expensive though seems to be safer due to unresolved organics etc?
