brown water after regeneration
Old 11-14-19, 12:24 PM
water boss softener model 180
after each regeneration the water is brown. I have to run approximately 25 to 30 gallons down the sewer to get clear water. I have been on city water for many years, and have never had this problem. the softener was installed in july of 2019. it worked fine for about 2 months before this started. I don't know what to do about it. the factory told me to get a filter. this is the same city water I have used for 60 years and have never had a problem.
Old 11-16-19, 03:27 PM
Mine had an similar issue but the water left a black ring. Mine had a filter cartridge thing inside that my installer had to repack. Cost me $300 I think but mine was 8 years old.
Old 11-17-19, 05:54 AM
Received 3 Votes on 3 Posts
There could be several causes but I suspect the issue may be impurities in the salt, particularly rock salt. Are you using cheap salt? Change the salt (use salt pellets) and see if it continues.
BTW, adding a sediment filter can extend the life of your softener but the filter would be installed ahead of the softener so it wouldn't impact your problem.
Old 11-18-19, 08:28 PM
thanks for the information. I will consider that.
Old 11-18-19, 08:32 PM
I will take this suggestion as a possibility, thanks.
