Pelican Filter/Softener/UV light install
Cannot reach Pelican support.
Does anyone have experience installing the Pelican Wholehouse filter/softener systems?
Have a question about the pre-soak of the carbon filter. Soak for 48hrs, then do the flush?
Thanks
Thanks
Welcome to the forums.
Allow the carbon tank to soak for a minimum of 48 hours prior to installation. !
Do not perform the Carbon Flush until the Carbon Soak process is complete.
Is that part you're questioning ?
Yes.... soak for 48 hours and then flush.
They don't want you to flow water thru the filter into the house until the carbon soak process and flush are completed.
Pelican manual (pdf)
