Fleck 5600 settings and Calcite/Corosex mix
Old 04-11-21, 11:36 AM
D
Question Fleck 5600 settings and Calcite/Corosex mix
Greetings to all. I'm new to the forum. I have a single tank aeration backwashing iron filter with a Fleck 5600 SXT control valve. I'm wondering what the correct settings should be especially the Valve Type (VT) setting. It has 1 cu. ft. of Katalox Light media. I'm also considering changing from a soda ash injection system for low PH to a calcite/corosex backwashing filter. I would like to know what would be a good percentage for the media mixture and is it calculated by weight or volume? My current setup is a cartridge type sediment filter-soda ash injector- iron filter- softener. The softener is a Whirlpool WHES-44 model. Water specs are: Ph 5.21, hardness 2.5 gpg, iron 1.1 ppm, manganese .5 ppm, tannin 1 ppm, alkalinity 7. The softener followed a chlorine injection system for years so I'm concerned about it's condition. Thank you for any and all advice!
Old 05-03-21, 03:11 PM
Akpsdvan's Avatar
Received 6 Votes on 6 Posts
How is it that you know that you have tannin?
Flow rate from the well?
