Which RO system should I get?
There appears to be quite a few to choose from. Which one's worth it that you can recommend? I'm looking for something under the kitchen sink.
RO systems are pretty universal assemblies made up of common components and all use the same filters/membranes/carbon blocks. Look for one that has the features you want and a name brand and your good.
I have an Essence RO system by APEC Water and I am happy with it. As Marq posted they are pretty universal so look for physical size and capacity. Also check on the cost of replacement filters. I replace 4 filters annually and the remaining 2 every other year.
With a 4 gallon tank the system will take up quite a bit of real estate under the sink. I put mine in the basement directly under the sink.
The only difference in the APEC RO system maintenance is that they recommend membrane replacement every 2 years if on a well and 2-4 years on municipal water. The 1st 3 stages are prefilters and APEC recommends replacing them every 6 - 12 months. I replace them annually but I am on a well and have a whole house filter which cuts down on the sediment before it reaches the RO System. A set of replacement filters is about $75.
what filters does my municipal water need?
I also have a well but with a very extensive water conditioning equipment so the RO system is getting clean water to begin with. I change my filters about every 2 years.
When I drink city water it tastes like pool water so for me chlorine removal (charcoal) would be #1 issue. Beyond that your just "polishing" the water to get as pure as possible.
Then there are the folks that put in a re-mineralization cartridge, doesn't make a lot of sense to me, purify the water then add minerals back in!!
