viqua sanitizer water softener skipping water hardness adjustment setting
Hello everyone! I'm new here and I just purchased a house with a water softner system. So awhile back I was farting around with the setting on my system going through them and learning about it. A couple days ago I went to check if my salt was low and noticed that the salt level has not moved and the brine level (water level) is half way up the brine tank. I checked everything on this unit from plugged flow tubes to removing most of the salt and water. I manual regened the system a couple times and notice that it would add water to the brine tank but only take a tiny bit back into the tank. I spent hours trying to diagnose what is wrong I then noticed that in the settings it will not allow to to change the water hardness (skips the step completely) when trying to change settings. Could this be the reason why my salt level has not changed? Is there anyone out there that could help.
Thanks a bunch Trent.
