GE gxsh39e water softener
Hi I have a GE water softener, model gxsh39e. There is water stuck in the tank. The error I am getting is Error 3. So far, I have tried reseating the valve motor wires and cleaned the parts of the venturi valve. Any help will be greatly appreciated.
Welcome to the forums.
Not my specialty but I do occasionally work on them.
Based on the error code you're getting it sounds like the motor may not be working.
I would check the two motor wires with a ohmmeter to confirm the motor is electrically ok.
GE manual -pdf
GE manual -pdf
