Culligan impeller question
Old 12-20-23, 09:17 AM
Moderator note: Removed from the thread at:Culligan Gold not regenerating or showing water flow
Just wanted to make sure I got it clear, in order to change/fix the flow meter impeller I would need to:
1. Shut off water supply first
2. Set Culligan unit in bypass mode
3. Run regeneration cycle
4. Once regeneration is completed and system is depressurized - turn off the power supply
5. Unhook the two screws on either side of the valve body holding it to the bypass
6. Take out turbine and clean it or replace with a new one
7. Put everything back
8. Turn the water supply back
9. Unscrew the bypass valve to set the unit in operational mode
10. Put the power supply back so unit will start regeneration
Am I missing something or maybe some steps are messed up?
Will appreciate any suggestions, because Culligan quoted me $469 pre-tax to replace this impeller with is quite steep
