PULSAtron injector pump and Hays Fluid Controll
Old 04-07-24, 08:53 AM
A
Received 2 Upvotes on 1 Post
All,
I am trying to troubleshoot a problem with our chemical injector pump and flow meter before I drop $$$ on a new pump.
I noticed that the injector pump is no longer operating when the water flows, I reprimed the pump and that works fine so do not think it is the pump. I am trying to figure out if I have a bad flow meter or other issue. Can anyone tell me how to test the flow meter? Also if it is a bad meter can you suggest a suitable replacement as it appears the Hays is discontinued?
Thank you in advance for the help.
Paul
Pics attached
File Type: pdf
