Soldering chrome towel rails?
Old 10-13-02, 07:06 AM
LRJ
I have a chrome towel rail with a cracked joint. Any suggestions as to how this can be repaired? Can I solder it?
Old 10-13-02, 09:52 AM
Usually that type of soldering is done before chroming and it will ruin the finish to put the heat to it. Is a slip joint and is it able to come all the way apart? If so you might be able to scuff the surfaces a bit and put some JB Weld in the joint, slip together, let harden and give a try,, wipe off excess at assembly. Might get some other ideas here yet too.
