Welding body panels
Old 04-06-03, 01:55 PM
wingplow
Welding body panels
I have a Lincoln Electric Weld Pak 100. Can this machine be used to weld body panels on a truck? If so is there any other options I need for this machine to weld the body panels.
Thanks
Old 04-07-03, 04:34 AM
WeldGod's Avatar
Yes you should be able to weld body panels, but you will need to pick up the MIG conversion kit for best results if your plans include welding aluminum you might consider the aluminum kit also. But for best results TIG is the way to go.
http://www.mylincolnelectric.com/Cat...eet.asp?p=7101
