Fixing outside railing?
Hi,
we recently bought a three family home in Mass,as rental property.
The outside brick steps have a wrought iron railing,wich is a good cond,other than the top pc,wich is rusting through.
Iam going to use a sawzall,cut off the top decrotive metal,and replace them with 1/4 x 1 1/2 wide aluminum.I will cut to fit,but I will be secureing it to 1/8" thk wrought iron.Iam going to bolt through,but wanted to use an epoxy too.Any ideas on this?It will be primed and painted to match after.
I want to minimize the bolts for apperance....Thanks
If it will be primed and painted why use aluminum? You need a primer suitable for use on aluminum. Also alum is quite a bit more expensive than mild steel.
Maybe you can use steel and have someone weld it so there will be no screws to see.
