UN-welding
Old 03-22-04, 07:22 AM
T
UN-welding
I have a metal basket That has the handles spot-welded on. How do I remove the handles? Thanks/Jina
Old 03-22-04, 01:28 PM
Ed Imeduc's Avatar
Well if you dont want to drill the spots out and have it fall off . You could try a very sharp chisel and work it under the edge of the handle Id have the inside of the basket on a iron mandrel When you do this. Are take a small hand grinder and just work away on each spot weld ED
Old 03-22-04, 05:21 PM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
thimblyjina:
If the handles are contact welded where you can't see the welds then prying and bending as Ed suggested might work and if welds are visible you may have to take a hack saw blade and cut the welds.
How thick are the handles at the weld?
