arc welding help types of metal
Old 06-24-04, 10:36 PM
greetings all I am knew to this welding bit. I have just a hobby 50 amp 110 electric lincoln welder. my can someone let me know if im able to weld galvanized? also will this weld stainless & aluminum? I understand that this will not weld thick gauge was just curious of what metal it will weld.
thanks to any and all who reply for your wonderful help.
Old 06-25-04, 02:44 PM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
scarrington,
It is unsafe to weld galvanized due to the toxic fumes that are given off.
If this is a stick welder you can get rods for stainless and aluminum but the low power would make it a frustrating experience.
I would stick to mild steel in a thickness no greater that 1/8 using 1/16" rod.
6013 would be a good rod to try.
