Electrical requirements for Miller Thunderbolt
Old 08-06-04, 10:21 AM
C
Received 6 Votes on 5 Posts
I learned some stick welding some time back, and every now and again I wind up thinking "if I only had a welder I could...".
I can get a loaner Miller Thunderbolt 225 welder (with the crank on top) that would serve my needs exactly. I'm not sure of the power requirements, though.
If I changed the power plug on this machine to match the wall receptacle for the clothes dryer at the house, will the welder work properly (and not burn down the house)?
Thanks-
Old 08-13-04, 05:00 AM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
That 225 should work fine on a stove plug. Make sure you use a heavy enough extension cable.
Here is PDF of a manual for that machine.
Old 08-13-04, 09:58 AM
C
Thanks, GregH
Thanks, GregH- I'm going to carefully choose the extension cable so it doesn't overheat. Thanks also for the link to Miller.
Old 08-23-04, 12:11 PM
It will likely trip the breaker on a dryer circuit,, as Greg said it will work on a stove circuit though. I would run one just for it though. Using cable use a number 8 wire and a 50A breaker and get the right recept to match the welder plug,, the grounding in the recept is slightly different than an old stove or a 3 wire dryer.
