wire feeder for engine driven welder
Old 08-15-04, 07:08 AM
D
I'm looking to buy a wire feeder for my miller trailblazer and don't know which one to buy. I weld as a hobby and have welded for others to make some extra $$$. I'm going to be fabricating a couple of trailers. I usually weld angled steel and will be welding 3" C channel.
It was recommended that I try the miller 3045fc because of the lower cost of this unit. I however was considering the miller 8vs or the other suitcase type wire feeders as it has a higher amp rating to match my welder output should I need more amps. Maybe someone could help with some suggestions. I plan to do all my welding outside. Thanks in advance. dave
Old 08-23-04, 12:07 PM
You are going to need to run fluxcore outdoors. Here is the place to ask, many of these guys have feeders for that machine.
http://www.millermotorsports.com/mbo...p?s=&forumid=3
