Improved
Old 11-18-04, 05:45 PM
metalfab's Avatar
Improved
This past summer I bought a HH 135 without knowing how to weld, though I knew I was interested in welding (used my neighbor's stick machine a few times ) . I was able to weld ok but, looking at my past 'passes' they don't look all that great and I'm sure the proper penatration wasnt there.
To make a long story short, I am now 7 weeks into my Metal Fab Citation course and haven't had a chance to use my HH 135 for atleast that long. I have been very busy with studying. In terms of welding, so far they have taught us how to Oxy Fuel weld and Stick weld (6013, 6010 and 7024) and I have been doing fairly well. So I thought I'd see if I improved on my own welder at home. I'm happy with the result, does this look ok to you? Any comments would be great as I still have a lot to learn.
Flux-core weld using a Hobart Handler 135. Tap setting 4, Wire Feed 40 on 1/4" mild steel. http://www.pbase.com/ajuett/image/36514782.jpg
Old 11-25-04, 05:38 PM
GregH's Avatar
Super Moderator
Not a bad looking weld.
A few hundred feet like that and then try one on your back under a vehicle trying to go around a muffler connection.
Old 11-25-04, 10:43 PM
metalfab's Avatar
The total length of that weld is about 1' ...99' to go I must admit I hit the slag a little harder than normal. I was welding with 6010 at school and was use to chipping a bit harder than usual
Old 11-26-04, 04:49 AM
P
Received 1,628 Likes on 1,461 Posts
What are you building that has a hundred feet of weld in 1/4" steel?
Old 11-26-04, 05:35 AM
GregH's Avatar
Super Moderator
I was referring to a hundred feet as an amount of practice weld.
