Welding cast iron to stainless steel?
Old 12-20-04, 12:54 PM
Chris Wilson
I have put up a photo of a Toyota Supra twin turbo cast iron exhaust manifold on my web site. It shows how Toyota, or whoever makes the manifolds for them, have welded in a flexible stainless steel expansion belows between 2 pairs of 3 cylinders. The manifold casting is definitely cast iron and magnetic, the bellows are definitely stainless and none magnetic. The weld fusion looks to have been an automated process. How is such a fusion done, and more specifically, how, in the amateur workshop with access to a decent TIG machine, can one offs of a similar nature be attempted? I would like to directly weld a flexible stainless steel bellows to a cast iron manifold to mount a wastegate on, which itself is rigidly suppoerted, the bellows being to allow thermal expansion and contraction.
Pic is at http://chriswilson.tv/manifold.jpg
Thanks.
Old 12-20-04, 05:46 PM
majakdragon's Avatar
Never seen it done with TIG but I know it can be done with stick welder. It takes a certain preheat and uses NIrod electrodes. Then a postheat and SLOW cooling period to assure it doesn't crack. Last time I saw a procedure like this, the part was buried in lime and wrapped in insulation for many hours. Sorry I don't remember the pre or post heat temps.
Old 12-21-04, 08:15 AM
metalfab's Avatar
You should be able to Gas Weld (Oxygen & Acetylene or MAPP) the 2 together, much cheaper if you don't have a TIG machine.
Old 01-22-05, 08:34 PM
H
NO E-MAILS, ADVERTISING or SOLICITATION
No Ads, Advertisements,Solicitations or Pyramid Schemes Allowed In The Forum Topics.
This post has been edited.
Advertisements within the forum topics or within replies posted or within personal signatures or including email addresses within replies or signatures is not allowed on this web site. Surveys, Ads, Advertisements, Solicitations to market products, services or to hire person(s) to perform work is not allowed in any forum topics.
Posting email addresses for others to contact to obtain information or to market products or directing anyone to personal web sites which can market products or solicit services, etc are not allowed. There Are No Exceptions.
Members posting any of the above or similar, anywhere on the web site are doing so in violations to the policy and are subjected to suspension or banning.
No topics are to be used for personal gain using any method. Allowing any of the above degrades the entire web site for all concerned parties. Read the forum sticky note for additional detailed information.
Doug Aleshire
Super Moderator
Last edited by Doug Aleshire; 01-23-05 at 08:22 AM. Reason: No E-mails/Advertising or Soliciation Allowed
