mig welder gas pressure
Old 12-21-04, 12:58 PM
shaggy
what gas pressure should I use ? I have a chicago electric 132t dual mig. I just started to use it with gas . Works much better than with the flux cored wire , but at this point , I'm just guessing what pressure to use .
I read in another thread someopne recommending 10psi . The problem is that my regulator is in (cu. ft. /hr).
The manual I downloaded says 5-7 l/min . I'd like to go by the manual , but how do you convert that to (cu. ft. /hr).
Old 12-21-04, 02:13 PM
G
one l/min = 2.118 cu. ft/hr
5 l/min X 2.118 = 10.59 cu. ft/hr
5 l/min = 10.59 cu. ft/hr
Note, Flex wire uses a different polarity then solid wire.
Old 12-21-04, 03:22 PM
A
Pretty Good GWIZ
I did the conversion slightly differently and came up with 5 l/min is 10.63 Ft3/hr. And 7 l/min is 14.88 Ft3/hr
Good point about changing the polarity when switching from flux core to solid wire.
Old 12-21-04, 04:25 PM
GregH's Avatar
Super Moderator
Did well with formulas in school, but I guess if you don't use it...................
I use this.
It comes up with 10.59 cf/h
There are a lot of other usefull conversions on this site.
Old 12-21-04, 04:55 PM
A
Greg,
Thanks for the site, I have bookmarked it.
Old 12-22-04, 08:33 AM
shaggy
thanks everyone . GWIZ , I did change the polarity .
