Glueing Metal?
Old 01-15-05, 08:43 PM
T
Glueing Metal?
I have 2 delicate pieces of metal that need to be glued together. I cannot used solder. What is the best adhesive to use for Metal? Thanks/Jina
Old 01-15-05, 09:10 PM
GregH's Avatar
Super Moderator
Jina,
Epoxy or silicone will glue metal.
What are these pieces?
Old 01-16-05, 07:26 AM
D
If it is a butt joint (think touching a fingertip to another) then any glue will have a hard time. A super glue adhesive might work, and there are several kinds (grades) of that available at good hobby shops (shops that sell models, not artsy places).
A better choice than silicone would be polyurethane caulk or gutter sealant. Any HVAC person should know how easily silicone pulls off galvanized sheet. I do not know why silicone is used instead of ploy.... Any caulk would be ok if gluing a sheet to a wall was the objective.
If it is a display piece not subject to handling, glue might work. Otherwise, maybe a trip to a jeweler is in order. If the item is a quality metal, it should be repairable.
Old 01-16-05, 02:02 PM
T
Question glueing metal?
Hi Greg-I am attaching a metal charm to a metal thimble. Have you tried the new cool touch solder iron? I wonder if that would melt either object. I have 15 of them to make. Thanks/Jina
Old 01-16-05, 04:57 PM
GregH's Avatar
Super Moderator
Not sure about the cool touch soldering iron.
A solder that would likely work would be radio/tv solder that is used for electronics.
You would have a dull finish though.
Here is a link to info on jewellery soldering: http://www.gold.org/jewellery/technology/solders/
Old 01-17-05, 12:50 AM
G
Try (JB weld) Epoxy.
Gray in color.
Sold just about every where. auto parts stores, hardware stores.
Not all metal can be soldered with an electrical soldering iron.
Find out what metal it is made out of.
Old 01-21-05, 05:19 PM
Chuckiechan
If you look around there are some low temperature solders out there that work at about 425 F. If you don't have any plastic or glass involved, you may be ok.
(or lead or peweter)
Old 01-21-05, 11:28 PM
hobby
i heard this stuff works good. its called fusor. www. lord.com. its a automotive repair adhesive, supposed to be stronger than weld.
Old 01-22-05, 08:27 PM
H
NO E-MAILS, ADVERTISING or SOLICITATION
No Ads, Advertisements,Solicitations or Pyramid Schemes Allowed In The Forum Topics.
This thread has been edited.
Advertisements within the forum topics or within replies posted or within personal signatures or including email addresses within replies or signatures is not allowed on this web site. Surveys, Ads, Advertisements, Solicitations to market products, services or to hire person(s) to perform work is not allowed in any forum topics.
Posting email addresses for others to contact to obtain information or to market products or directing anyone to personal web sites which can market products or solicit services, etc are not allowed. There Are No Exceptions.
Members posting any of the above or similar, anywhere on the web site are doing so in violations to the policy and are subjected to suspension or banning.
No topics are to be used for personal gain using any method. Allowing any of the above degrades the entire web site for all concerned parties. Read the forum sticky note for additional detailed information.
Doug Aleshire
Super Moderator
Last edited by Doug Aleshire; 01-23-05 at 08:23 AM. Reason: No E-mails/Advertising or Soliciation Allowed
Old 01-22-05, 08:29 PM
H
Doug Aleshire
Super Moderator
Old 01-26-05, 06:05 PM
PegLeg
Get it clean first
At work we would use a spray electrical contact cleaner. This woeked great when preping alum for heli-arcing.
