(MIG) Filling small holes
Old 03-11-05, 06:59 PM
_BobF
Using .024 wire with Argon/CO2 I can weld new-metal patches in 20 gauge sheet metal for large holes, but when welding over small holes (like old sheet metal screw holes) I always end up with a small 'mountain' of tacks about 3 times as high as a regular bead. What's the better way to weld over these small holes? The only other thing I can think of is to cut a bigger hole about 1/2" and make a patch.
Old 03-12-05, 08:24 PM
filling holes
try drilling out old screw holes with a slightly larger bit to get rid of dirt/rust. if you still have difficulty,if possible use a copper or brass back plate to absorb excess heat.
Hope this helps,
Mike
