Bending T6061?
Old 05-25-05, 05:37 PM
R
Bending T6061?
I have 2 pieces of Aluminum round tube (T6061) x 4' long ID = 1" OD = 1 1/4"
I need to bend both of them in the middle to about 120 degrees. 180 degrees being straight. Can I do this myself or do I need a shop to bend for me ? This stuff sure is pretty hard.
Mike
Old 05-25-05, 05:53 PM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
Mike,
A bender for tubing has a shape to prevent it from kinking.
An electrician would be someone who could do this for you.
You could also try a machine shop.
Old 05-25-05, 05:56 PM
R
Thanks for the quick reply Greg. I have an electrical conduit bender, but this stuff is way too tough to bend on it..
Old 05-25-05, 06:32 PM
GregH's Avatar
Super Moderator
Muffler shops have benders that have a follower that is the same shape as the tube and pushes against the back to force the tube around the die.
I use this style for a/c tubing but it is only common for my trade to have sizes up to 3/4" od for residential a/c.
I don't do a lot with aluminum tube and can't be sure what you have can actually be bent.
Hard drawn copper tubing like regular water line is too hard to bend in a bender and will kink.
If I have to bend hard drawn I will heat then cool the section to be bent which takes the brittleness out of it but you can't do this with aluminum.
Maybe if you try a machine shop they will be able to advise you on this.
Old 05-25-05, 07:36 PM
Tig185
Visiting Guest
Posts: n/a
Lightbulb Bending aluminum tubing
I have done that type of bend up to 90 degrees. You will need to fill the aluminum tubing with a low temperature metal alloy bending material. If not the tube will kink in the bender. You will need a helper and some oil and a strong arm if manual. It is important to bend very slowly. When the bend is complete, hot water will usually allow removal of the material (sometimes a light pass with a propane torch). Follow manufactures instructions to the letter. I save the material and reuse it because it is expensive. Do a web search for "Cerro bend".
