Cutting metall railing
Old 11-10-05, 08:04 AM
Larryu's Avatar
I'm not sure if this is the right place to post this,but I recently bought one of the diy metal railings.The instructions say to cut it with a hacksaw.I did and it looks bad.I am looking for sugesstions on how to make nice cuts on this stuff.
Thanks
Old 11-10-05, 08:18 AM
majakdragon's Avatar
You didn't say exactly "what" looked bad. I would suggest a jigsaw with a metal blade if the hand hacksaw doesn't provide the cut you want. Or you could rent a chopsaw if the pieces are flat. Good luck.
Old 11-10-05, 09:01 AM
Larryu's Avatar
You have to cut this stuff to length and what I was cutting was mitre cuts as I am using it as a handrail on steps.
Old 11-10-05, 10:04 AM
IBM5081's Avatar
Rent a portable bandsaw. Called a portaband in the trade, they are made by Milwaukee, Porter-Cable and others. Harbor Freight has some very economical knockoff versions that might last a little while.
You will probably want to clamp the rail to hold it securely. Because the bandsaw does not reciprocate and has a stop to hold it against the work, you will get a smoother cut. Clean off the burred edge with an angle grinder.
Old 11-10-05, 10:10 AM
Larryu's Avatar
Okay.Thanks
Old 12-26-05, 04:04 PM
CAHILL24
Metabo
If you have a lot to cut you should think of getting a metabo, it's fast and has a clutch to keep from being injured.
you can pick them up at most home improvment stores
