Arc welding aluminum possible for a beginner?
Old 11-20-05, 09:08 AM
ghostdog 5.0
I have a 200 amp arc welder, a real inexpensive one I might add, and I am needing to weld some 1/4" aluminum plates together.
I can currently weld steel with no problem but I've never attempted aluminum before. Do I just need to the appropriate electrode and amperage setting?
I am a beginner but have gotten plenty of practice in school.
Thanks
Old 11-20-05, 06:36 PM
majakdragon's Avatar
ghostdog 5.0, Welcome to the DIY Forums.
I have not done a whole lot of aluminum stick welding but when I did I found that the amps have to be high. The machine I used ran 1/8" 6010 at 85 Amps. I used 95 Amps for 3/32 aluminum rod. You will have to do some practice to get the temps/amps correct. Pretty purple arc. Runs like melting butter. Have to go rather quickly. Good luck.
