Refinising a wrought iron aquarium stand
Old 06-04-06, 04:22 PM
mako's Avatar
I have a wrought iron aquarium stand that is about 15 years old and has some surface rust. I'm selling it all and want to do something to clean up and refinish.
I plan on coating it with black rustoleum, which is handy b/c I have some laying around.
Anyhow, how do you recommend I strip the rust off? I'm guessing use an angle grinder with a wire disk and blast it off? Should make short work of it and the old finish, I'd assume.
Thanks,
Matt
Old 06-04-06, 04:54 PM
majakdragon's Avatar
Sounds like a good plan. If it is ACTUALLY just surface rust, you could use steel wool and then wipe with a rag before painting. Good luck.
Old 06-04-06, 07:28 PM
mako's Avatar
Well, it's rusted beyond steel wood but not by a lot. I'm confident a wire disk on the angle grinder will do the trick. I don't get the chance often to use it and make sparks, it will be fun.
