cleaning rust off sheet metal
Old 07-27-06, 01:19 PM
B
I have a large piece of galvanized sheet metal that's been rusting outside for about six months. Anyone know the best way to go about cleaning the rust off? I've tried scrubbing it with steel wool, which got rid of some surface rust, but it's still far from shiny.
Old 07-27-06, 05:05 PM
Are you planning on painting it after the rust is cleaned off? A sanding disc for a drill or disc grinder will probably clean 99% off. When galvanized starts rusting the zinc is gone and will need to be primed and painted.
Mike
Old 07-27-06, 07:06 PM
B
Thanks, dude. I need to glue stuff onto it, but the glue won't stick right if there's a lot of rust. Looks like I'll have to get a sanding disc.
Old 07-28-06, 06:37 AM
T
you might try white vinegar and a wire brush, it works a lot better than you would think.
Old 07-28-06, 10:31 PM
T
Navel jelly also removes rust. It's available at the hardware.
