mig welder repaird
mig welder repaird
have a century 100 amp wire feed welder model 83101, 117-064, when turn on, only fan is working. tried to locate the reset button which the manual says it is on the drive deck, but cannot find it. Is the thermal protector the same thing. does anyone have a wire diagram that may help or know how i can troubleshoot where the problem might be. the diagram that came with the welder does not help any.
I have a different name brand mig welder and once with my welder the trigger switch on the nozzle handle acted up and only the fan operated.
The wire had come loose from a micro switch that was under the trigger.
