what do i need to cut a half inch diameter piece of round metal
Is there any hand saws i could use or a angle grinder best?
For just a few of these cuts, put the metal rod in a vise and use a hacksaw with a fine-tooth metal blade.
If you have quite a few to do, a portable bandsaw does a quick neat job of it.
I cut through a 1/2 inch thick piece of metal pretty easily.
The biggest and smallest diameters of the things im cutting are 100mm and 200mm.
I used a hand saw with small teeth. Will this cut neater than an electric saw?
