Home Made Stick welder?
I see this guy on you-tube;
Grant Thompson, the King of Random.
With his home made stick welder.
He has lot's of interesting tools as well.
As well as a home made spot welder.
I need a Spot welder to make a battery pack for my Battery powered drill.
Have any of you made this Home made Stick welder?
Occasionally I need one. I have a Big TV set with a couple transformers in it.
Don't know what else I might come up with.
Have we had this on the forum in the past?
I'd like to be able to study some plans.
I just spent most of my lunch break watching several of his videos. Lots of useful stuff on his channel. I think the spot welder would be a great project.
FWIW I've rebuilt a few battery packs and so far I haven't needed a spot welder. The tabs or battery ends are tin plated and can be soldered with an ordinary electronics soldering iron & a large-ish tip. It helps greatly to pre-tin the batteries and bridging tabs with solder & flux before trying to daisy-chain the batteries together. Once pre-tinned, the terminals solder together easy & if your iron has enough wattage and contact the solder will flow out smooth.
Bridging tabs can be made from a strip of thin brass from a hobby shop or perhaps copper foil from a stained glass supply. I've also used small braided grounding strap, desoldering braid, or small bits of bare wire.
