Help regarding hinge pin
I'm not sure if this is the right forum, but i basically have this weights bench and it has a seat you can ajust on serveral inclines, you see where i'm going with this. anyway it requires a hinge pin to be bolted in. Which i have, but after slotting the pin in & securing it it's still very wobbly, could it be because the tube it passes through is to girthy? This pin came with the bench but it also came with some rubber bushing's and i lost the manual.. thanks so much i'll post pictures in a bit if this thread draws any interest.
