Wire feed welder not feeding
I have a Century wire feed welder model #117-052-003 (110V). The wire feed does not feed when trying to weld. It feeds normally when not welding but as soon as I get the arc it quits. Any suggestion as to what the problem may be?
I would go to the Century site, and then contact CUSTOMER SERVICE. Now if you have the manual, maybe it will give you a hint. Customer service is probably your best GOOD advise.
Dale in Indy
Dale in Indy
Does the drive wheel stop turning or does it loose traction and spin on the wire.
There are a few things that can cause spinning on the wire, wrong drive wheel, lack of pressure on the wheel, worn contact tip, dirty liner, etc.
