Turning a round 1" copper solid bar on lathe?
I am wanting to turn a piece of 1" OD copper solid round stock. It is C101 Oxygen free H04 material, labelled HARD COPPER.
I want to turn it into the shape of a BULLET. Approx. 2" long, actually want to turn down to 7/8" OD, than shape the front like a BULLET.
I want to do this on my Wood Lathe.
I am very arty, have lots of experience in metal and wood working, but not turning copper.
Comments are needed, and I can't be offended, so fire away.
Dale in Indy
Dale in Indy
Dale, not my forte, but I believe you will need a 4 jaw clamp to turn the billet with. The pokey type arbors on standard wood lathes just won't grasp the metal, IMO.
I was thinking using the CENTER HEAD SPUR, and the LIVE SPUR on tail stock. I would take a hack saw and cut a + in the head spur, and drill a center counter sunk in the live spur.
I was going try a file first to shape it.
Hoping someone has more info.
Dale in Indy
Dale in Indy
Just thinking out loud, but the stability of a cutting tool to machine even copper is far more than hand held. I know you weren't thinking of doing that, but my thoughts lean towards an active cutting tool, like a grinder. While the stock is turning a grinder passed across the length would provide a rough stage towards where you want to be.
Just a thought. These days I just take my ideas to my nephew who owns a machine shop, much easier.
Bud
Bud
Received 38 Upvotes
Copper is one of the more difficult metals to machine. On a regular metal lathe it cuts a long, snarly curl of metal rather than chips. On a wood lathe I would suggest that you use a coarse rasp and even that will soon become clogged with the metal. A long rasp pushed slowly while the billet is turning MIGHT work okay but the finish will be rough and you will need to use a finer toothed file for finishing and finally using sandpaper. If you want a polished finish it will take a LOT of work.
what the others said
File it, grind it, sand it.. just don't try to cut it with a handheld tool. I take it this isn't a precision operation and there's no tolerance involved, just aesthetics.
Yep, going to chuck it in my lathe, and go at it with files, etc. Don't have any plans to take a wood turners wood handled tool for the process, although a very experience wood turner I know has done such, and said just use a SCRAPER, not a GOUGE.
Just looking for a Bullet shape, not an exact piece.
Dale in Indy
Dale in Indy
Dale in Indy
Dale in Indy
