Angle bars vs flat bars stregnth
Old 04-28-15, 10:08 AM
D
I need to put some support under a granite countertop. Instead of making actual support brackets, I want to use steel bars running across the counter extended out 10" to support a 12" over hang. Should I use angle bars or 1/2" flat bars for this?
Old 04-28-15, 10:11 AM
Received 361 Votes on 318 Posts
Angle iron is always stronger than flat steel of the same thickness. Anytime you put a bend in steel it becomes stronger.
Old 04-28-15, 10:28 AM
D
perfect, thanks for the quick answer
Old 04-28-15, 04:27 PM
Handyone's Avatar
Below "rods" are what we use as a rule. The 3/4" height closely matches the thickness of the plywood underlayment.
If you are installing 3cm granite, there will be no underlayment and rods need to be recessed into top of cabinet.
Best to go over this with your installer.
Old 05-10-15, 06:34 PM
D
dam
I would put decorative wood gussets under the overhang
