best tool for gouging out a thin line in metal
Old 05-04-15, 11:31 AM
V
I am thinking something like a graver but most gravers don't seem to be that effecient at gougning out a hair thin line in metal. I want to do it by hand if possible.
Old 05-04-15, 11:41 AM
Received 753 Upvotes on 658 Posts
Not sure what you are trying to do would a scratch awl work?
Old 05-04-15, 11:44 AM
B
Received 47 Upvotes on 43 Posts
Thick metal, thin? How thin of a line and how deep?
All machine shops have tool bits that can cut into metal, the question is how to hold them for the job you want.
Something like a block plane with a blade sharpened, shaped, and hardened could follow a guide with down pressure and an adjustable depth.
Now, lets see what the real machine people have to suggest.
Bud
Old 05-10-15, 12:09 PM
C
Received 23 Upvotes on 20 Posts
I know this post is a touch old but here's an idea. How about a 4 1/2" angle grinder, with a thin cut-off disc? The discs are 3/64" thick. Add a safety guard to allow you to cut to a certain depth: it would be like setting the guide on a circular saw to cut at a certain depth. (The cut-off discs wear quickly, though, so you'd need to set the depth fairly frequently.) If there's a Harbor Freight near you, you could get it all for about $25, less if you use a coupon.
Just for curiosity, what's the application?
