is there any kind of solution that will fuse two pieces of metal together
I am thinking of probably a liquid solution of some sort that might breakdown some of the molecules of each metal and fuse them together. I need a solution other than soldering to attach gold sheet to silver. I don't like to solder because the gold melts to easily and we know how expensive gold is nowadays.
There are specialty glues used for almost everything, but I know of nothing that you describe. There is also micro-welding although I've only read a little on the subject.
Another thought would be, could the parts be plated together, as in electroplating?
How rigid does the final product need to be?
Bud
Bud
