Century wire feed motor
Old 01-14-18, 08:01 AM
i sent in a post previously for a 1996 Century Model 117-037-903 that had a bad fan motor which i rep;laced with success. However when I went to use the welder a day or so ago, I could not advance the wire with the hand gun. (blew a house circuit breaker) I reset the breaker but if I hit the trigger now the wire feed motor (I think) buzzes loudly (does not advance the wire) I released the wire tensioner to see if the motor would even turn, and it wouldnt. I have THIS motor out now and would like to test it before ordering a new one. It appears to be A 24 VOLT DC motor rather than the AC type motor the like the fan was.
What is the best way to test this motor? I find it strange that I would lose two motors at the same time. What else could need replaceing in the circuit?
Old 01-14-18, 05:17 PM
Century Wire Feed Motor
I got the test procedure off Utube and it passed the test. I got it to run by itself with a 12 Volt DC power supply. I put it back into the mchine and hit the trigger on the wire feed gun. I got the same buzz sound, but determined that it came from a part beneath the wire feed motor. It is listed as a "reactor" part number 860-670-888. I have been unable to find one on web searches. Is this available anywhere you guys might know?
Old 01-14-18, 06:30 PM
A 24vdc motor fed with AC will make a 60hz chatter.
The schematic I'm looking at shows the wire feed motor connected directly to the control board. The reactor is a welding process transformer. It won't affect the wire feed.
Old 01-15-18, 10:41 AM
Well I was just going to where the noise was. but go figure... Before I read your latest post, I called the number on the original owners manual for customer service and was referred to Lincoln Electric, who must have bought out Century. Customer service there, verified your diagnosis (if it not being the "reactor" but possible diodes or a "triac" relay that is mounted on the Fan box (remember that I had a bad fan I had to pull out and could only remove by removing the box. which included removing diodes and the triac. SOOOO I probably put something back together wrongly, The rep from Lincoln told me I could call him back when it was more than 17 degrees farenheit in my garage, and he would assist me in trouble shooting. When it is above freezing, I will dig into it and post back.
Thanks for the replies!
Old 01-15-18, 02:16 PM
I see the diode plate. Doesn't show where it's mounted but it's not part of the power supply that runs the wire feed. There is a 24vac drive transformer that feeds the control board directly. That is converted on the control board to the DC voltages that run the wire feed and gas valve.
Old 01-15-18, 03:07 PM
Diode Plate
I can see it too, but Jim at Lincoln says that a bad diode or triac relay would
cause the overload which makes a loud buzz, and trips my breaker when I hit the trigger for the wire feed motor, not the reactor.
](although I would swear that the reactor is what is making the noise. Their number is 866236 0044 (select option 2) if you want to discuss it with Jim. None of this will make sense to me until I find something, or replace something that doesn't test on a meter like it is supposed to. Repaired a lot of stuff, but never a welder, If you two figure it out, post it back to me. It is too cold here for me to work unless I know exactly what to fix so I can get back inside fast!
Old 01-15-18, 03:22 PM
Ahhhhhhhhh....... you were assuming it was the wire feed. Ok..... it's most likely not.
When you squeeze the trigger.... multiple things happen. The gas valve opens, the wire feeds and the voltage for the spark is turned on. Yes.... looking at it that way.... it could be a diode or wiring problem and the wire feed is ok,
If the reactor transformer was feeding into shorted or miswired diodes.... there could be a problem.
It would be time to fire up the ohmmeter.
Old 01-15-18, 03:31 PM
Wire Feed
I originally did think it was the wire feed. Even took the motor apart. (thought the noise was coming from there, but it was underneath the wire feed assembly. I'm hoping that it is just one of the wires I disconnected to remove the fan box but I'm glad you and Jim are at least on the same page if not the exact paragraph!
Thanks!
Old 01-15-18, 03:33 PM
I'll come out and fix it but you gotta supply the transportation.
Old 01-15-18, 05:51 PM
Century Wire Feed
That is a tempting offer, but it will be easier for you if I fix it here, and give you the credit for it.
"There is no limit to how far you can go, or what you can achieve in life, if you don't care who gets credit for it" (Harry Truman)
Old 01-24-18, 09:50 AM
Century Wire Feed
I had a warm day here, so I got the welder case off exposing the innards again. I took out both diodes and they check out ok according to what i have seen. ( Ohm meter almost pins needle in RX1 with leads going one way, moves only slightly with leads hooked up in reverse) the small 4X2" panel mounted on the side of the fan box must be the Triac, but I have not called anyone yet about the procedure to test that. Anybody had one of these fail before?
Old 01-24-18, 10:02 PM
Triac ?
I don't see that listed in the schematic. I do see 4 lead component..... could that be it ?
Looks three white wires and a yellow wire to it.
Can you check the red and black receptacles to ground ?
I don't think there should be any short to ground on them.
Old 01-25-18, 08:57 AM
4 lead receptacle
On the schematic it might it is listed as a relay, in the parts list the corresponding code says it is a "triac- relay" There are 4 leads attached to it. two of them go up to the top of the fan case and attach to a small round disc (thermostat) held there by two sheet metal screws.
I will go out later and recheck where the other wires go exactly. "from the description I just gave you above, something is wrong. The two wires ( one yellow and one white) , both are not supposes to go to thermostat from the relay, just the yellow one is. on the schematic here in front of me. The white wire heads for the terminal board, on the schematic, but I don't believe the one that is actually there is long enough to do that. it is the same length as the yellow wire which just makes it to to the top of the fan box. Ill get back to you.,...
Old 01-25-18, 01:20 PM
Century Welder motor replacement
Ok, I checked the wires against the schematic and I found that the wire going to the thermostat mounted on top of the diode plate was on the correct terminals. The other wire was attached to that wire but went all the way back to the circuit board. All good there. HOWEVER (and I have to take the blame for this) there are two other terminals on the relay marked ONE and TWO . Both of these terminals had brown coated wires fastened to them. One went to the transformer and one went all the way to the main on-off switch.
These were switched. SOOOO now I guess the FIrst place to check is to see if I fried the relay. OHM meter is reading continuity between terminals 1 and 2. but I dont know if they are supposed to. There is no continuity between relay terminals 3 and 4
With everything back to where it is supposed to be. (I think) If I hit the trigger for the wire feed, it snaps the 50 breaker in the box on the garage wall RIGHT NOW (no buzz ,no nothing. (if I re set it , I can get the cooling fan to turn on again) Now Im stuck again.
Old 01-25-18, 03:58 PM
I called Lincoln Customer Service. They had me take the Triac relay out of the circuit by disconnecting the brown wires that go to the switch and the transformer. This allowed me to test all the switches that engage the wire feed motor, the gas valve and other controls, which I could hear all engage when I hit the button in the weld gun. They then told me to connect the two brown wires together (with tape) which would also bypass the triac relay but should activate a power transfer so you can weld. Hooking thee two together shut down the machine when I turned on the MAIN power switch. i did not even have to toggle the gun.
They have asked me to try to run it with just one diode hooked up to try and see if one is bad even if it tested ok with an Ohm meter. I plan to do that tomorrow. There are one or two capacitors in this circuit, Any know how to properly test these?
Old 01-26-18, 08:52 AM
Testing a Triac
No one wants to tell me how to test the "triac" which to me is the smoking gun to the solution of this problem. the wires to it were the only mistake I KNOW I made in reassembly after repairing the motor.....
Old 01-26-18, 04:51 PM
Is the triac the four lead part ? I don't see it on my schematic.
A triac is only a three legged semiconductor.
Did you check the ports like I asked ?
Old 01-27-18, 10:05 AM
You were asking me to check the ports. I'm not sure if what I checked is what you mean, but I checked the main black leads that go from the fan box to the main transformer (and one red one) for shorts and continuity. result: no shorts and complete continuity. (The guy from Lincoln was walking me thru this)
Yes the triac relay that mounts to the fan box has four leads. two brown wires going from terminals 1 and 2, and a yellow and a white wire that go from terminals 3 and 4.
I googled " how to test a triac" yesterday and got a response from Electronic Circuits and Diagrams-Electronic Projects and Design - An Authentic Resource on Electronics which walks me thru the tests of the Triac I have. I will get after that and post my test results. If it comes up ok, it will be good (triacs are expensive!) If bad, at least I can get one and keep going!
The guy from Lincoln says that even a positive test on the diodes can be misleading. He wants me to disconnect one diode at a time and see what happens when I hit the gun. If the triac is ok, I guess that is what I will do next
Old 01-27-18, 01:36 PM
Trac Testing
The triac failed the test BUT the test instructions said "this test is not applicable to triacs with high gate voltage and current for triggering " If the number one on the triac itself is MT1 per the test, it says 240V AC for "output" Terminals 3 and 4 have a note on them as being "INPUT" 3.5-26V If the gate is on this side of the triac, I tested it in the wrong place. I could use more help here!
Old 01-27-18, 02:36 PM
Been crunched for time lately. I'll be back to see if I can help further.
  #21
Old 01-27-18, 03:59 PM
Diodes
With nothing more important to do, I went ahead and put the triac back in the machine, and removed one of the diodes. I started the machine and triggered the weld gun. It worked! I have the diode on the table in front of me, but it tests ok with a multimeter. Other forums and posts indicate that this is normal. The diode can still be bad. I only have two, (both the same part number) so unless you say to do something else first, I guess I will order both of them. Polarity shouldn't matter if they are the same diode, right?
  #22
Old 01-27-18, 07:16 PM
If it's a factory part it will be marked. Diodes are a DC component and are polarity sensitive. It may work with one diode but that will only output half the current. Try the same test by swapping diodes.
What meter are you using for testing and does it have a semiconductor setting on it. Looks like the picture of a diode symbol.
When testing diodes..... probes in one direction should show no continuity. Reverse the probes and you should measure several hundred ohms.
  #23
Old 01-28-18, 09:22 AM
My Ohm Meter was probably used by Edison. It does not have the semi conductor setting. The diodes in the part list are just one part number for both, and I do not see any polarity indicators on the one in front of me. Probe test indicates it is ok (at least with this meter) So swapping diodes, if I get the same result, (machine still works with half Power) or do you want me to but them both back in on opposite sides?
  #24
Old 01-28-18, 11:42 AM
Ok.... in looking over what I have for a schematic.
Terminal 1 - to power switch
Terminal 2 to large transformer
Terminals 3 and 4 to the control board.
That part cannot cause a short circuit..... or a short to cause the breaker to trip. That part takes low voltage and uses that to control the high voltage. I can't call it a triac as a triac is a three legged device. If that part directly shorted on it's own.... the welder would be at full amperage and running.
The diodes are bolted on a common metal plate/heatsink..... correct ?
Hmm.... something just hit me.... I think that metal plate needs to be insulated from the metal chassis/case. Check that out.
  #25
Old 01-31-18, 09:14 AM
Diodes
The diode checks kind of like you say with the setting at RX1 one way no continuity, the other way 10 Ohms of resisistance At the Rx1K setting I get SOME continuity testing one direction, and get about 4 ohms resistance going the other way. I will head to the garage and cross check these with the other diode and see if the plate is not touching anything. It would seem to me that if it was, It would be shorting out and blowing the breaker now when I hit the trigger, as all I did was remove the one diode. I will let you know!
(I get it about the triac being a 3 legged component, it just happens to be what Century calls this relay in their book. It is wired exactly as you described)
  #26
Old 01-31-18, 09:40 PM
That is a bad diode. I'd change them both.
  #27
Old 02-01-18, 08:55 AM
Diode Testing
Everything points in that direction, I'll make the order out today. you will here me cheering all the way to New Jersey when the welder lights up!
Thanks!
  #28
Old 02-05-18, 09:39 PM
Century Wire Feed motor
I replaced the diodes today and got the same result. If I trigger the gun, I trip the main 50 amp breaker in the wall box. If I remove the diode on the left side of the Fan box (as you look at it from the back of the welder) I can trigger the gun without tripping the breaker. Could one of the capacitors be doing this?
  #29
Old 04-08-18, 09:11 PM
Century Wire Feed Motor.
I told you guys you would hmear me cheering in New Jersey, (I'm in Ohio) If I got my Welder working. you all get to laugh at me, as the buck stops with me. I apparently miswired the fan cage when reassembling it after installing the new fan motor. There are some very large wires that come from and or go to the capacitors and or the transformer.. A friend who has a Century welder like mine took it to his shop and opened his up next to mine and he spotted my miswiring immediately. He changed the wires and hit the gun with a spool of wire in the line and welded away. The cool part is that i did not destroy anything, and i only bought one diode for 30 bucks that I didn't need. He also found a schematic on the inside of the main case which showed the correct way to wire it. So next time I will take pictures religously !
  #30
Old 04-12-18, 04:49 AM
No laughing here! Good on ya for having the stones to dig elbows deep into unfamiliar territory. Not too many would have the "dang the torpedoes" attitude to take on that job. Embarrassing, maybe, to re-assemble it wrong, but lesson learned and a fairly cheap lesson to boot. Glad you're up and welding again!
  #31
Old 04-12-18, 06:10 AM
Glad you stuck with it! Steve
  #32
Old 04-12-18, 07:22 AM
Century wire feed
Thank you for your kind words!
  #33
Old 04-12-18, 12:28 PM
Oh.... that was you cheering. I thought it was a lion roaring.
  #34
Old 01-08-19, 06:15 PM
I added on to this post from last year because the specs on the welder were on the front side of the post. I have been welding successfully for a year with this after the fix but I seem to get a pitting effect in the weld beads after they cool off. the pits are small and in the surface of the bead, easily hidden with body filler or Jb weld. What am i doing wrong with settings or whatever that might be causing the small pits?
  #35
Old 01-09-19, 03:47 AM
GregH's Avatar
Super Moderator
I skimmed the whole thread and don't see anywhere you stated what type of welding you are doing.......shielding gas or flux cored wire.
If flux core, the welds do tend to be not as pretty as when using a gas shielded weld.
If flux core you could try a fresh spool or wire brand/type and possibly an anti-splatter spray might help.
If using a shielding gas maybe a different shielding gas flow rate or wire type /brand may work or if you are using straight C02 as a shielding gas it does not weld as clean as a mixed gas.
  #36
Old 01-09-19, 08:44 AM
Thanks for the reply Greg. I am using Argon/Co2 mix shield gas, not flux core. I have a adjustments for heat and wire feed, but I don't see one for gas flow rate on the machine. I may not be the best at cleaning the surfaces to be welded, I may have to get better at doing that. I am normally welding steel of various thicknesses for lawn and garden equipment applications.
  #37
Old 01-09-19, 11:14 AM
GregH's Avatar
Super Moderator
The flow rate for the gas would be on the regulator connected to the tank.
Normally you would use a predetermined flow rate but can change it for various reasons.
Presumably you are welding indoors as shielding gas will be blown away in even the slightest breeze.
Make sure the metal is clean with no paint or oil.
You could try an anti-spatter spray which might help.
Almost all my welding is done outdoors and I use flux cored wire which does not have near as nice an appearance as with gas.
  #38
Old 01-09-19, 01:53 PM
I didn't think about the gas valve on the tank when you said adjust the flow....I do most of my welding inside so the wind is not the problem for me. I will have to be more carefull with cleaning though. I know I have just burned thru the paint many times. No wonder I get that result! Have a great day!
