Copper pipe brush
Old 12-07-18, 08:37 AM
Copper pipe brush
I got one of these. For cleaning copper pipe before soldering.
https://www.amazon.com/Pipe-Cleaner-.../dp/B01GOY3CGE
I works good but its heavy duty. Leaves scratches. Would you use this pre solder?? I know sandpaper
leaves grooves deep enough to leak. I could hit the copper with a plastic pad to mellow out the scratches I guess. But in your experience is this really made for
copper pipe as opposed to battery terminals.??
Old 12-07-18, 08:48 AM
Norm201's Avatar
Received 672 Upvotes on 595 Posts
I've used sandpaper, battery post cleaners and similar, even scrapped with a knife edge when nothing else was available. Never had a leak due to the cleaning method.
Old 12-07-18, 11:01 AM
P
Received 1,775 Upvotes on 1,587 Posts
The scratches are there for a purpose. It's part of the cleaning process and helps form a stronger joint. Scratches from sandpaper and cleaning brushes do not cause leaks. The solder flows into the scratches and seals them. The fine scratching also provides some mechanical teeth to provide more surface area to further strengthen the solder to copper bond.
Old 12-08-18, 09:12 AM
i know scratches can cause leaks. I have seen it. But I wont worry about these. If I used 80 grit sandpaper I know I could have leaks.
Old 12-08-18, 01:53 PM
Norm201's Avatar
Scratches won't cause leaking if soldered properly. Capillary action will fill and seal those grooves and add strength as PD suggested. Your joint should be almost cherry red (not quite) and apply solder to joint and it will be sucked into the space between the fitting. Let it cool naturally, NEVER blow on it or use water on it or let it move. That will cause a "cold" solder and cause a leak.
Old 12-08-18, 02:55 PM
XSleeper's Avatar
Received 1,721 Upvotes on 1,545 Posts
I use green Scotch Brite pads. Never had a problem.
