I've got a drain plug that is giving me fits. Its an ordinary 3/4" npt magnetic drain plug, with a square female fitting. And its so tight that the side of the female fitting has busted off, making it impossible to remove with a 1/2" square socket adapter, since it now only has 3 sides and is now even more difficult to remove.
Ordinarily I would ask my dad to weld a nut onto it, and then use a regular socket on it. Problem is, dad is getting old and no longer can do this sort of thing. Last time I tried to have him weld up a steel hinge onto a door he just kept burning holes in the steel. So I really don't even want to ask him for fear he might burn a hole in this gear tank.
I guess my next thought was, would jb weld work for this? Would it have enough holding power, once cured, to hold the nut onto the plug so that I could break it loose? Or would it just not be able to hold that much torque? Any thoughts?
This is on my skid loader and I really don't want to take it anywhere to have it worked on if I don't have to.... its parked in the garage and I'd like to do it myself, if possible.
I also thought I might stick a short 1/2" adapter into the female plug with jb weld all around it. That might be better than a nut.
Since I would be squishing the male socket extension into the jb weld that I put into the female plug, I guess my thought was that it just needs to hold it tightly against the 3 good sides.
Maybe I just need to drill it out with a 1/4" or 3/8" bit and then use a nipple extractor (big easy out).
Or maybe I need to try using dad's welder myself and weld a bolt into it.
This is what I would do. I've used JB Weld for various tasks and have generally been satisfied with the results, but you have to recognize its' limitations, and I would not expect it to do hold up for this particular task. And you could try welding something to it yourself if you wanted, but the problem is that whoever does it is going to be upside down, in tight quarters I imagine, and if it doesn't do the trick now you have weld to contend with if you did end up needing to drill it. So probably not all that easy to get to, but I'd skip the welding and go to drilling it. Just go easy with the extractor, and if it doesn't look like it's going to work you can always step your bits up to where you need to be to peel it out with a small chisel. Extractors have their limitations too, and a broken one can turn it into a real chore.
End of the work week... I had some time to work on this again... decided to give up on the jb weld idea and the weld a bolt onto the drain plug idea and just drilled it out. I figured drilling it out would be better since if I tried to weld and failed, the welding rod would make it really hard to drill out. First I eyeballed it and drilled a 5/32 hole in the center and then knocked the old magnet off the back with a nail punch. Then used my 7/8" step bit to plunge straight through the old oil plug and 1/2" thick body. It helped that oil was trying to drain out as I drilled... it was self lubricating that way!
Then took a small chisel (like you said aka pedro) and peeled what was left out. I must have hit the center pretty well because the old threads just needed a little cleaning up once I peeled the old part out, which was like collapsing a thin ring.
Glad that is done... now I just need to rinse the tanks with diesel fuel (per the operators manual) before refilling them with oil. (Cleans the sediment out of the bottom of the pan) Dad has a bucket (recirculating) pump that should work good for that... will just let it circulate for 30 min or so. I swear the old oil was so nasty. Wonder how many years its been in there.
Diesel fuel works well for cleaning out nasty crankcases. I've also used mineral spirits and kerosene. On an old neglected engine I'll add a half a quart or so about 5 minutes before an oil change and let it circulate while running.
If the pan has a good bit of sludge it might be better to remove and clean it.
Fortunately this is just a gear case, (no combustion) so it seems pretty clean. I think the nasty color of the oil is from 40 years of dust and rust since it probably gets a little condensation in it via the breather. (Gramps wasn't big on maintenence) But I do want to rinse out the metal filings from drilling out the old plug.
Removing it isn't possible. If I completely dismantled the entire skid loader to get it out, (including all the wheel axles) it would probably be the 2nd to last thing to come out.
Hi folks, looking to see if you have any recommendations to cut metal. I searched on here and there’s a few conversations about it, but they don’t seem to be about the same metal that I’m trying to cut. I need to cut the metal shell of a clothes washing machine (the top loader kind, not front loader kind). Not sure what type of metal that is (steel?), or what thickness, but it’s got a little thickness to it as opposed to an aluminum downspout which is a lot thinner. I have a table saw, chop saw, grinder, jigsaw, and circular saw. I’m assuming the circular saw or grinder might be my best bet. (For a little better description, the “shell” that I’m referring to is if you were to look at the washer, it’s one piece of sheet metal that goes from the left side, to the front, to the right side....poorly pictured below haha.)
thanks!
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/320x222/d7790025_34b2_44ed_ac20_12ea1a79dfc3_e314104aa28ed5af6de70700e192a5d982941d87.jpeg[/img]
Hi folks, Hoping you could give some advice regarding a broken peace on my treadmill‘s circuit board. As you can see in the picture, there’s a female connector that gets soldered to the board and that’s where the display cable plugs in. It’s an eight wire connector and looks similar to an ethernet cable sort of. When I opened up the treadmill and looked, the connector was no longer soldered to the board. I’ve soldered things before, but nothing to a circuit board this tight before. When you look at the board, it looks like the metal is partially missing where this connector would solder on. Do I still have the ability to solder the connector to the board?
Thanks!
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1650/4606051f_37bf_4a39_93c4_4dfc4e0f20a8_4bc7ad268a838ede86786b96a7e02dfd3828a314.jpeg[/img]
[i]The red arrow is where the connector should be soldered to the board. [/i]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1626/794160f1_1132_4caf_bb26_bbba4fb55177_9a247c3d8c4fb9a08f652bfb7e54ef7b8c933c08.jpeg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1587/425e1688_b3f2_4470_adf6_d6cf8a703513_e5872d10f46daa75705928ee6e8321bc4dcade41.jpeg[/img]
[img]https://cimg7.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1190/6ad89560_5bf2_4a16_91c1_fbe007a612b6_5223aac8e87234f8dff028cb38df64dec349b8eb.jpeg[/img]
