Hi, I have a problem that is getting worse with my Snap On welder. It is made by Century. I love this welder, because it does everything I ask of it. Lately, like the last year, it has been sticking in the " On " position. Like if I would pull the trigger on the gun, the loud hum will continue, even if I release the trigger. Some times when I turn the power switch on, it will do the same thing. Is there a contactor of some sort that is NOT releasing ? It takes re arching to stop it, or just to turn it off and turning the machine back on. Sometimes it will do it over and over and get real frustrating. Other times it will do it and them not for a day or so. It sounds like something it sticking and won't release, but it is in the " weld " mode, if that makes sense. I don't know if the internal workings of a welder, but it something that is sticking or hanging up inside the machine.
The diagram is the control board. The two pins with red arrows are the trigger connection. You could monitor those with a voltmeter when the system is on or connect an ohmmeter with the system unplugged to check for shorts. A short on those two pins is what activates the switching contactor.
The pdf below is the schematic.
Among other old and rusted tools found an old rusted pair of tin snips in the collapsed work shed at my cabin (must be about 30 years old). Cleaned them up and found a brand name of WORTH. Did a quick look up in GOOGLE. Apparently they are not considered a very good brand. Anybody know anything about the company.
I managed to get them in working order. But I don't have the right angle to get a good clean cut.
Also found an old fine tooth rip saw. The teeth feel sharp. What's the best way to clean it up. Also needs a new handle. I think it's worth saving.
Hello Community!,
I have metal paneling on my wall that got scratches from wiping with abrasive material (accident). The white stuff looks like parts of a "skin" when it gets rubbed on concrete to put it in perspective. Is this repairable without having to replace the paneling. I have this on long walls so the price will not be cheap if I replace them.
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/pxl_20210408_185620675_b8dbb377a0632c607f95486ac89ccfd121d32e38.jpg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/pxl_20210408_185629063_3fe5e42ea8b807d715fe69a6b00f9b0e5858c653.jpg[/img]
Thanks!
Pictures of wall Attached.
