can you flux core weld over powder coating?
Old 03-08-24, 06:44 AM
Received 4 Upvotes on 4 Posts
I have two pieces of metal that have been powder coated.
do I need to sand them down to bare metal before I flux core weld them or can I just go ahead and weld over the powder coating?
Old 03-08-24, 08:02 AM
P
Received 2,231 Upvotes on 1,990 Posts
Sand down to bare metal. Powder coat paint is basically polyester so you often can't strike an arc or attach a ground without cleaning to bare metal. Once you have a spot cleared you can start your arc there and move into uncleaned areas where the heat burns off the paint. It makes a lot of smoke and makes a poorer quality weld so it's best to clean the entire area you intend to weld.
Old 03-08-24, 10:07 AM
Received 860 Upvotes on 752 Posts
It's always best to have bare clean metal to weld to. Welding thru paint complicates things and makes it harder to get a nice weld.
Old 03-08-24, 08:48 PM
thank you all
I'll just sand down, weld, and re-powdercoat
