Gravity fed system with pressure tank?
I am trying to design a gravity fed water system for my cottage. In order to get decent pressure can a pressure tank be fed from a elevated water tank and increase pressure to the cottage?
Any help or pointers to information will be appreciated.
ps. there is no power at the cottage.
Received 1 Upvote
1 Post
A pressure tank is designed to sense the water pressure in order to control the pressure switch that turns a pump on and off.
By itself, a pressure tank won't increase pressure.
An elevated tank can. (That's the purpose of public water towers...volume and pressure.)
Here are a couple of sites that are great tutorials that may help you get a handle on this.
www.peekspumnp.com
www.jessstryker.com
Good Luck!
Mike
www.peekspumnp.com
www.jessstryker.com
Good Luck!
Mike
krg,
Mike is right about the pressure tank.
A pneumatic tank would not be of any use but just a regular tank would be.
If you stuck a 50 gal tank, 20 feet in the air you would have about 10 psi based on about 1/2 psi per foot of elevation.
The size of the drop pipe would only need to be sized to the flow.
Off grid cottage
Thanks for the feedback.
Water is for 1 tub and 2 facets in the cottage. Currently use a cistern pump for my needs. I really wanted to have decent water pressure and not have to built a tower 40+ feet high to do it.
Will have to look at alternative powered pumps (solar).
If you can drive your vehicle right up to the door you could use a 12 volt pump and a deep cycle battery you bring in each time you go there.
If the battery went low during your stay your vehicle could power the pump.
