wet spot on field
Received 0 Votes
wet spot on field
Before replacing the drainfield, I would definitely try diverting the weeping tile water off into a sump pit away from the septic system.
Ground saturation, clay soil, and system overload are combining to cause the problem of septic water bubbling to the surface, as you know.
You also might try installing drain tiles or ground swales around the drainfield to help divert snowmelt and rain water saturation as much away from it if you can.
You may alleviate the problem by adding another drainfield line, instead of replacing the whole field.
Call your Health Department septic system permitting tech out to advise you.
You'll need a permit and inspection from them anyway in order to alter your system with another drain line.
Good Luck!
Mike
Good Luck!
Mike
