well pump turns on without water running
Old 10-04-04, 08:05 AM
stevesg
I have a well pump that is almost 20 years old, but in good shape. The pressure is good and I have never had a problem with it.
Recently, I have noticed that the pump turns on every few hours - without any water being used. I have checked for leaks (faucets, toilets, pipes) and found none, also I have turned off the water feed to the pump for a few hours, and the pump stays quiet.
What do you think? I'm trying to check all avenues before I even think about purchasing another pump. Thanks.
Old 10-04-04, 08:18 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Do you have a check valve there that leaks back on it?
ED
Old 10-04-04, 09:07 AM
stevesg
the check valve looks o.k
Old 10-04-04, 09:13 AM
stevesg
ED
check valve looks o.k.
Old 10-04-04, 09:14 AM
Mike Swearingen's Avatar
Sounds like a check valve problem to me, too.
Even though it looks O.K., it might have build-up in it from the well water or just a weak spring or seal, not allowing it to seal completely.
I would take it apart, and check it out.
Good luck!
Mike
Old 10-04-04, 09:29 AM
stevesg
Good luck!
Mike
Thanks ! I'll "check" it out.
