well pump help needed
can some one help Im stuck on stupid or something It been a long time since I,ve worked on a well pump I am trying to seperate the pump from the motor to repair pump and can,t remember how to do it the pump I have is sears 1hp convertible shallow well pump the pump is about a 1985 vintage that when it was installed
Usually you hold the motor shaft and remove the impellor and seal behind it. Usually there are wrench flats on the motor shaft, some ca nbe hard to get to.
Gary
xxxxxxxxxxxxxxxxxxxxxxxxxxxx
Company Name Removed Only
Doug Aleshire, Super Moderator 2
Gary
