Pump Tripped Breaker
Old 12-25-04, 03:58 PM
lilsusan63
Thumbs down Pump Tripped Breaker
About a week a ago I turned the water on, no water.Check the breaker it was not tripped but, I tripped myself then pump came back on. Now it happens everyday no matter how little water I use.
First- changed out breaker with another one-Still doing the same.
Filled the points.
Still tripping.
What is wrong?
Susan
Old 12-25-04, 04:23 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Turn the breaker off and check out the pressure switch for loose, burned or corroded wire connections.
If it's not a problem with the pressure switch electrical, it may be in the pump motor.
Good luck!
Mike
