Submersible pump runs constantly, Help!
Old 12-28-04, 01:01 PM
thundercoach
Hello all
My Pump cuts off at 60 and cuts in at 45, as soon as the pump cuts off at 60 it immediately goes back down to 45 and then the pump kicks on again to 60, what can it be?? does it have anything to do with the settings of the 2 coil nuts?
Old 12-28-04, 11:54 PM
nomind's Avatar
Location: langley, in sunny fraser valley, bc , near vancouver
Hi Thundercoach,
- you most likely have a leak down the pumpdrop, could be a split in the pipe, or a broken fitting, checkvalve etc. Start checking at the top of the well, by listening for water spraying out . You'll probably have to pull the pump up to repair it properly.
