Sump pump backup advice
We live in an area of frequent power outages. They generally last a couple of hours. Worst case has been 36 hours during the recent ice storms. I am looking for advice on battery backup sump pumps (needless to say, one storm too late). I am wavering between a backup, or just buying a generator. Any advice? Are the battery backup pumps (Watchdog for instance) difficult to install myself? An should the mid level model do, or am I better off with the top of the line for the extra $200?
Thanks for any input!
Hi Ohiochip,
-most of the back up pumps are very easy to install if you have some mechanical sense. You certainly don't have to be a plumber or electrician to do it.
Having said that, I have a friend who's a computer genius, but is barely capable of changing a lightbulb - there are always exceptions.
I have heard good reports about Watchdog, but never used one.
There are also water powered models that are reputable.
If I was you I'd scan these threads and you'll find MANY references that will be helpful.
Do it Right - Do it once.
Hi Ohiochip,
-go for it, you know you can do it!
Please post back with results after you ace it.
Get you a pack of cable ties that are 8-12" long. That way the 3 wires coming out of the pit will be out of harms way and makes the job neat and tidy.
I go through a pack every time; you definitely don't want any loose wires holding the float switch down.
